How much slack on your P/S belt?What pulley are you using on your P/S pump? NA pump you must use NA pulley and a TT pump you must use a TT pulley They are the same diameter however the offsets are different. Did you fill up your reservoir while the engine was running? Let me know what you find after checking these. There’s just not enough info to go by based on your first observation.
